Yet another oil feed banjo leak thread
Throwback23
222
7
Apr 28, 2012
Boring, Oregon
I recently noticed I had a leak after my turbo install. I assumed it was the oil return but found out it was a slow drip that was seeping out of the banjo and down the oem 1g oil feed. I figured it was the crush washers so I got some new copper crush washers and torqued it down to 15lb/ft yet it still seeps through the bottom of the washer closest to the banjo head and down the line. Anyone have recomendations of what I should do? I read in another post to tighten it a little more but that didn't seem to work...anyhow thanks for reading and any input helps!
Found and fixed my problem, oil feed lines head had a imperfection (due to pliers) and wouldent seal... good to not have a leak anymore!
