wtf is wrong
nAiFk1e
79
Sep 30, 2009
Mckinney, Texas
i changed my 2g stock turbo to a td05 14b and put a fitting on the top of my jpipe for the boost controller. now my blow off isnt working (yes i know i need to be recirculated but i still havent picked up that kit) and my car bogs hard under light boost, any ideas?
have u done a leak test since 14b install. if not, theres your problem.
I know everyone always says blt, but thats because its so often the problem.
Check for boost leaks. 5-10$ will build you a nice one. If your car is blowing off correctly, then you definitely have a leak. If not, check your connections to your controller and etc..
