wtb transfer case 1g 1992!!!!
O2 housing with sensor
Drive shaft
Fuel Rail with stock 450 injectors
23 spline transfer case
Power steering pump
Stock blow off valve
Ebay type RS blow off valve
Cam angle sensor + bracket
Throttle body elbow 1G
Passenger window
Misc Intercooler pipes
Throttle cable
Shift boot
Battery mount
Distributor
Radiator
Intake manifold
Valve cover (no leaks)
Wastegate actuator (stock 9psi)
6 bolt flywheel
Crankshaft
Engine Mounts
J pipe
Ecu (runs car fine but tachometer gauge cuts in and out)
Misc Pulleys
15" Black universal wheels 4x100 or 5x114.3
