would this radiator fit??
Cheks_Talon_TSi
228
3
Oct 24, 2003
Monterrey, N.L., Central America
The radiator of my 1991 Ealge Talon TSi FWD is loosing fluid from the upper plastic part of the radiator.
Some friend of mine has an aftermarket radiator for a 1991 Eagle Talon N/T and he is selling to me in $20.00dlls (a new one from autozone is moreless $120). It seems to be find and in good conditions but my question is: those that aftermarket radiator (of a N/T) would fit in my car exactly as the OEM one? :rolleyes: :rolleyes: and, those it is of the same capacity?
Hope some one can give me an advice and answer me my questions...
Thanks in advance...
Sergio G. :thumb: :talon:
Best bet would be to pull your broken one out and compare them. Check thickness and if your not getting fans with it, make sure your's will fit. also make sure the mounts are in the exact same places (probably are, but you never know).
I can't compare both radiators because my friend live far away from here. Any more ideas???
Does the radiator of N/T is the same as the one on a Turbo (in same year cars)???? :confused: :confused:
Thanks!
  • Wanted 6 bolt NT water pipe
    • chrisman287
