would this fit a 16G
That would probably be a direct bolt on for both turbo's, since its 2.25". With the t25 you will use the small factory rubber adapter thats on the comp inlet to get a proper fit as the t25 inlet is smaller then 2.25". When you go to bolt it up to a 16g, which has a larger inlet, the 2.25" coupler should fit right on the inlet.
