Would it be wise to!!!!!!!
slekimtr
Sep 8, 2005
Nazareth, Texas
Hi everyone. I have a 90 Laser FWD Turbo and I have all the necessary parts to do the brake upgrade. I took the calipers, brackets and hardware off of a 92 Diamante. The thing I was wondering was can I safely remove the 2 brake lines and replace them with 1 long SS line if I routed it the same way? I have been checking around allot for SS lines to do this and I am having trouble locating the lines in prefab form for what I want to do. Any suggestions are welcome on the safety issue and where I can buy prefabs. Thanks
If you can get rid of 2 and go to one and leave out one place that it could leak that would be great and just run it so that the line cant catch anything like a tire or debre on the ground or what ever then just zip tie it so it cant get cought on anything. ss is the way to go good luck finding what you need. :dsm:
I called Earls and Russell. Both are willing to make me new lines to accommodate what I am doing with the brakes. All I need to do is make sure I follow the original shape of the stock set up and give them the measurements. Guess I will use a piece of rope to do this. Thanks for your info.
