would evo 8-9 brakes fit on an early 95.
ImportWarrior
308
Jan 18, 2004
Rochester, New York
would evo 8-9 brakes fit on an early 95. I have the lovely vented rears and would like to do away with them. I tried the search and did not see any mention of the evo 8-9 calipers or rotors installed on an early 95 talon. could this be an option for me or do i have to stay with the vented rears.
Thanks.
:beatentodeath:
first off, why would you want to do away with those brakes? they are bigger, run cooler (vented) and provide more balanced braking....
but second, to answer your question, yes/and no. you can get evo 8/9 rear calipers/rotors and bolt them straight up, if you have the clearance with your wheels for the added thickness of the caliper. and for the front you would need a different front spindle/knuckle from a european/jdm spec galant to bolt them up, and then you would still need to have the clearance with the front wheels.
it has been done on 2g's and there is a write up in the tech section.
I thought that the early 95 would put the caliper in a different location. That is why you could not use the brembos on the rear. It is hard to find early 95 parts. I want an easier more abundant setup.
thanks for the link.
    • george bromwell
    • pma1123
    • Sdcryan1
