WOT pulls need help advice little issues.
M4s73r
102
Aug 26, 2012
St. Joseph, Missouri
So yesterday was the first day of WOT tuning. Starting slow on it. Im getting a little knock in a few spots but its small 0.4, 0.7, 1.1 and thats it. Tried a few things to get it out. Just not for sure what else to try. Here are a couple of logs,
My fuel trims are in line and my combinedft at idle is in range also. (it goes to -3.9 at wot?)
With no fuel adjustment at all I am in the 9.2-10.2 afr at wot on the wide band, are my injectors set right?
Is the small .4 - .7 blips phantom knock?
Should I pull more timing out?
Heres my last log.
I agree with what pat said.. set your cel to come on at anything above 5 through link and monitor it that way.
Just for reference, my cel comes on at 3 counts.
Also don't use both the sliders and the direct access tables for tuning. The sliders are easy to learn but the direct access tables are better to use. You are taking alot of timing away. I would change your knock settings to like 3000 rpm and 40% throttle, those numbers are up to you. For your injectors being right we need a idle log, and cruise log.
