WOT problems
Cloudsever
Mar 4, 2009
Missoula, Montana
WOT the car struggles to gain rpm or acceleration, but if you ease into WOT it seems to accelerate ok. Its on a 6bolt any ideas?
you have no info about your car. we need to know if you have a bigger turbo, bigger injectors, what psi are you running, do you have an stock mas? it could be a boost leak or i could be knock. we need more info if you want people to help. fill out you profile with your up to date mods
Sorry i should have specified its not my car I'm looking into buying it everything is stock except BOV which is a twin vented BOV it might be leaking i can see the piston and it looks like its at the half way position at idle, other then that it just has a new exhaust manifold.
There's a problem already. It's venting without haveing a translator or the GM MAF cable + ECMLink. :nono:
Causing the car to run rich.
ok so that is the problem with my car i have a hsk bov that just blows into the atmosphere ... i feel like i lack so much power in WOT ..... thank god im do my blow thru setup which should fix this :pray:
