WOT knock and lean
phantom_19
410
Oct 13, 2007
curacao, South America
Hi
I have a 1993 awd talon with a good ECU, 2G maf,880cc and a FPR 255 wally.
Today I did a 3rd gear pull up to about 6K because I was scared of going further. I knock about 7-9 degrees at 4-6K. I am really scared. My base timing is correct at 5 degrees at idle.
Can anyone look at my log and see what needs to be done? I also have a WBlog.
Its a wideband commander by dynojet
Time TP RPM AFR
12.230 14 1899 14.8
12.339 15 1906 14.6
12.448 17 1910 14.6
12.558 21 1913 14.7
12.667 46 1923 15.3
12.776 73 1969 14.9
12.885 105 1943 13.6
12.994 105 1973 14.7
13.104 105 2015 15.2
13.213 105 2014 15.1
13.322 103 2035 15.0
13.431 103 2074 14.8
13.540 106 2091 14.7
13.650 105 2113 14.7
13.759 103 2139 14.8
13.868 103 2167 14.7
13.977 103 2187 14.7
14.086 103 2216 14.8
14.196 103 2248 14.8
14.305 103 2265 14.8
14.414 103 2302 14.7
14.523 105 2326 14.8
14.632 104 2354 14.7
14.742 105 2389 14.6
14.851 103 2411 14.6
14.960 103 2453 14.6
15.069 103 2480 14.6
15.178 103 2507 14.5
15.288 103 2539 14.5
15.397 103 2573 14.4
15.506 103 2602 14.4
15.615 103 2637 14.3
15.724 106 2680 14.3
15.834 106 2712 14.1
15.943 106 2747 14.0
16.052 103 2793 13.9
16.161 103 2829 13.9
16.270 103 2860 13.8
16.380 105 2905 13.7
16.489 103 2950 13.8
16.598 103 2984 13.8
16.707 106 3034 13.7
16.816 103 3080 13.8
16.926 103 3116 13.9
17.035 106 3163 13.8
17.144 103 3209 13.9
17.253 106 3260 13.8
17.362 103 3291 13.8
17.472 106 3347 13.8
17.581 103 3383 13.7
17.690 103 3420 13.6
17.799 103 3468 13.7
17.908 103 3516 13.6
18.018 103 3563 13.6
18.127 103 3606 13.5
18.236 103 3640 13.6
18.345 104 3694 13.6
18.454 103 3736 13.5
18.564 106 3792 13.4
18.673 103 3827 13.4
18.782 103 3866 13.2
18.891 103 3905 13.1
19.000 103 3972 13.0
19.110 103 4016 12.9
19.219 103 4054 12.8
19.328 103 4095 12.7
19.437 103 4146 12.7
19.546 103 4199 12.6
19.656 104 4238 12.6
19.765 103 4288 12.5
19.874 103 4336 12.4
19.983 104 4391 12.4
20.092 103 4439 12.4
20.202 103 4477 12.4
20.311 104 4527 12.6
20.420 103 4584 12.6
20.529 104 4630 12.5
20.638 103 4680 12.7
20.748 103 4734 12.8
20.857 104 4787 12.7
20.966 103 4844 12.8
21.075 106 4885 12.8
21.184 105 4951 12.8
21.294 106 4983 12.9
21.403 106 5045 13.0
21.512 105 5105 13.1
21.621 104 5181 13.2
21.730 106 5209 13.2
21.840 104 5268 13.3
21.949 105 5346 13.6
22.058 106 5404 13.6
22.167 106 5443 13.7
22.276 104 5508 14.0
22.386 106 5565 14.1
22.495 104 5629 14.1
22.604 106 5670 14.1
22.713 94 5698 14.2
22.822 5 5708 13.7
22.932 5 5727 11.5
23.041 7 5543 11.1
23.150 7 5313 12.9
23.259 5 5086 14.1
23.369 5 4871 14.3
23.478 7 4648 14.3
23.587 7 4414 14.3
23.696 6 4246 14.4
23.805 5 4259 14.7
23.915 5 4233 14.5
24.024 5 4204 14.1
24.133 7 4194 13.6
24.242 5 4181 14.4
24.351 5 4171 17.9
24.461 5 4164 18.0
24.570 7 4154 18.0
24.679 5 4144 18.0
24.788 5 4136 18.0
24.897 4 4124 18.0
25.007 5 4107 18.0
25.116 7 4097 18.0
25.225 6 4083 18.0
25.334 5 4066 18.0
25.443 5 4052 18.0
25.553 6 4037 18.0
25.662 6 4021 18.0
25.771 5 4009 18.0
25.880 4 3988 18.0
25.989 6 3968 18.0
26.099 7 3950 18.0
26.208 6 3925 18.0
26.317 7 3905 18.0
26.426 5 3890 18.0
26.535 5 3868 18.0
26.645 5 3842 18.0
26.754 4 3817 18.0
26.863 7 3798 18.0
26.972 6 3781 18.0
27.081 5 3752 18.0
27.191 7 3736 18.0
27.300 5 3712 18.0
27.409 4 3688 18.0
27.518 4 3665 18.0
27.627 7 3634 18.0
27.737 5 3486 18.0
27.846 5 3290 18.0
27.955 6 3125 18.0
28.064 4 2951 18.0
28.173 5 2789 18.0
28.283 7 2622 18.0
28.392 7 2485 18.0
28.501 7 2559 18.0
28.610 6 2825 18.0
28.719 7 2826 18.0
28.829 7 2821 18.0
28.938 6 2812 18.0
29.047 5 2804 18.0
29.156 7 2798 18.0
I noticed that the boost keeps rising after 4.5K. I have a autometer gauge and it shows 12 psi from 3K till 4.5K then rises to almost 18 psi. It should be constant right?
I have the WG from my big 16G mhi hooked up to a nipple on the throttle body
I did add some fuel in the fuel tab, only about 6% max. When I checked it just got leaner by a min of 0.2 on each rpm row
The boost is likely creeping because that turbo cant flow enough exhaust out the wastegate to hold boost that low, and also, the line youve got from the wastegate to the tb is way too long, causing delayed response. You really want this line as short as possible, and ideally, as close to the compressor cover as possible. You can weld a 1/8" NPT bung to the j- pipe, screw in a 1/8" npt nipple for a 3/16" hose, then hook that to the wastegate if you dont have a boost controller- this is the proper way to do this, but the boost will still increase with RPM, so if youve got a FMIC, just get the AFR at WOT in check and the timing advance, and shoot for 20psi boost with a boost controller and itll hold better.
The following is copied and pasted from your log. In this area, you are way too lean (unless youre running E85, then its still too lean) and theres too much timing advance in this area as well. If this is on 93 pump, dont even go WOT until youve got the lean condition under control or youre going to melt something. Hows your maf comp? Do you have it so that boost est is on par with the boost youre running? Make sure your global setting for the injectors is correct for the manufacturer's injectors, not just the advertised size, and set the deadtime the same way, make sure your base fuel pressure is correct. Then, play with the fuel and timing maps on the DA tables. If youre on pump, start out with 10.5:1 in the load cells youre hitting at wot, if your maf comp and injector settings are close, the wideband will read at near what youve set your cells to. Why not just download the EVO timing map from the ECMLINK site and tune from there? The EVO timing map, or even a 2G timing map would be a good start and should eliminate knock due to too much timing.
