Won't go into 2nd gear
cramec2
56
Sep 7, 2004
Manchester, Connecticut
95 Talon TSI AWD 5 Speed..How much do you think it costs to has syncro replaced at shop?
if its just the 2nd gear synchro maybe not that bad but if its slipping to more than one gear then its gonna add up.... and if your skipping from first to third it will catch up with you eventualy. i drove from florida to LA with the forth gear synchro messed up... i skipped that gear everytime... and when i got to LA it was about a week then it tore up the whole tranny... i would charge about 1k if i had to replace someones tranny... thats rebuilding the whole thing. but iam guessing from about 75-110$ because of labor and all it might vary... and there definatly going to find more wrong with it...bet on that....hope i helped somewhat... go around and get quotes from different tranny shops...
I am looking into buying a 95 tsi awd 5 speed..1995 Eagle Talon TSI AWD - 5 speed - Mods: T28 Turbo, no
> shaft play. Larger Sidemount. Walbro 255 Fuel Pump. Full 3" Turboback
> Exhaust. Greddy Type S Blow Off Valve. Magnacore Spark Plug Wires. K&N
> Cone Filter. Autometer Boost, EGT, and A/F gauges. New Act2600. Viper
> Alarm. HKS Turbo Timer.
> Lowered about 2". 97-98 Talon Front Bumper. Brand New Battery
> Pioneer Speakers. Momo Shift Knob. Kenwood CD player. Front and Rear Sway
> bars. The bad: Needs a 2nd Gear snychro. The gear itself is ok. It should
> cost about $500 to have a shop fix the tranny, less if you can take it out
> yourself. Car has 80,000 on the Engine, 155,000 on the chasis. Engine
> runs great, no signs of crankwalk. I have done both the "hard left turn"
> trick, as well as watched the RPM's when the clutch pedal is pushed in.
is this worth 4g's
