Wiring wizards needed
ohyeah
46
Jun 13, 2011
denver, Colorado
Well yesterday i posted a thread about my because it was not logging, i went and reviewed my wide band wires and noticed the wire that goes to the ecu was loose. I did not wire in my own wide band so i do not know where it goes , i have both front and rear o2 sensors in. Ive been searching for where the wire should go and most people say in pin 75 or 76 but those are people that aren't using their front or rear 02 , i do not have a cat, and my wide band bung is lower than my o2 sensor on the down pipe. with that being said should it still go into pin 75 or 76 or is their somewhere else i could put the wire so that my wide band will log on dsm link? thanks in advance
Pin 75
76 is for the front 02
I personally use my wideband in my stock 02 housing bung and have the narrowband simulation signal wired into the front o2(76) and the wideband signal into pin 75 for logging. So only 1 o2 sensor to worry about, and it's fully compatible with a stock ecu
