Wiring an a/f gauge
miamieclipse
1,143
3
Oct 26, 2003
Miramar, Florida
Hey guys i need some help wiring an a/f gauge. The stupid thing did not come with directions and I am not good with wiring at all. Anyone know of a tech article that can help me out? Anyone have some personal experiences?
Any info is appreciated.
autometer, i got the install guide from a friend. Thanks for all the help!
send that guide my way mike, mine will be here this week too ;)
I believe its the black wire with the white stripe on the top 02 sensor you hook up the wire to. It may be white with black stripe i forget. Then just red to power and black to ground. :thumb:
just got them today. EGT and A/F. when you say black and white whatever wire and red wire, your talking about the big wad of wires coming out of the ecu right?
on the SAFC install guide on 2gnt they say power is Black/White and o2 is white/black... so same for the gauge right? all in the upper ecu connector?
A/F wire is the Black with White stripe. You can tap it at the O2 sensor or the ecu. I recomend the ecu, its a little cooler. Just don't do what I did.... I hooked it to the TPS the first time I put it on..... Couldn't figure out why it didn't work right :p That was over 2 years ago, god was I a retarded ricer :thumb:
