which wire for A/F Gauge?
Status
Not open for further replies.
ac49er
81
May 16, 2004
Laramie - WyoTech, Wyoming
i have all of the wires hooked up for my air/fuel ratio gauge except for the one that goes into the O2 sensor...i located the O2 sensor and there were 4 wires coming from it, and im not sure which one i tap into..? anyone done this before and have any idea which one to use?
don't use one of those wires, you need to tap the wire from the ecu. (under the hood, if you can't find it you should not be trying this). I believe it is the only white wire under there. Go here www.2gnt.com and there is a section that has the pin/color wire to use. It may be different from a 95-96 to 97-99. I can't rember its been so long.
here i found it for you
http://johnseclipse.tripod.com/welcome/id8.html This is for both oil pres and the a/f install.
Status
