2G Wire tuck/ moving components
silentscreamer
106
Oct 11, 2008
Moncton, NB, Canada
This has probably been covered but from what i have dug up in a search i havn't found my answers.
i have removed my hvac and put my chassis fuse box in the center console like many others but my questions are this. has any one moved the power transistor unit into the cabin? i know the power resistor has been (turbosax2's fuse box relocation project). i am thinking about placing everything from the mpfi, fuel pump, starter relays, power transistor unit, power resistors and all other necessary equipment behind the glove box mounted to the fire wall so that they are all easily serviceable (which will hopefully be never).
i am just concerned that moving the power transistor unit too far from anything could create some kind of delay in the ignition system (which is curable by changing the timing but i would rather not have to worry about possible problems this could bring into things).
let me know your opinions on this.
Thanks
