wire loom
samus21
150
Jan 27, 2012
York, Pennsylvania
I'm relocating my fuse box to the glove box and relooming it but I wasn't sure what size loom I will be needing. you have the wire coming off the fuse box thas pretty big then it splits off into the left and right side. So what two sizes will I need?
You could maybe extend the fatter wire before it splits. but either way id suggest finding out the size and using the same size wire.:hellyeah:
You mean the protective sleeve that goes over it or the gauge of the wire? Wire should be bigger to alternator. Good cheap insurance basically. Helps charging and helps with voltage drop.
If you are referring to the sleeve. IDK. I know oreillys sells high temp sleeves at dif diameters and lengths. Im going to tuck my wiring this winter and plan on using that
I'm in the process of doing this as well. I have mine de-loomed on my garage floor at the moment. the size of loom you will need depends on how many wires your going to run together in it. I'm goin to buy a few feet of 1/8" 1/4" and 3/8 or 1/2" to start on mine if i need a diff size ill have to order it..
  • Wanted 6 bolt NT water pipe
    • chrisman287
