[RESOLVED] mystery wire coming from same loom as injectors
akira235
386
5
Oct 16, 2008
c,
like stated, its a wire and i have no clue what it goes to, all the other wires go to plugs, o2 sensors and i don't know what else. some of the harness was cut/damaged so i started soldering things back together and i noticed a yellow wire with a green (i think) stripe that seemingly goes to nowhere. suggestions, help, or references would be very much appreciated.
all i know for sure is one plug in that area is an o2 sensor. left side of engine, after the injectors.
'90 talon tsi awd
<a href="http://s422.photobucket.com/albums/pp307/akira235/?action=view&current=untitled.jpg" target="_blank"><img src="http://i422.photobucket.com/albums/pp307/akira235/untitled.jpg" border="0" alt="Photobucket"></a>
blue notes the plugs extending from the loom (o2 sensor, coolant temp sensor, i dunno what the third one is) red is the wire in question. its yellow w/ green stripe
There are two sensors on the t-stat housing. The upper one has two wires, the lower only has one. I'm not sure of the colors, but I do believe the lower one is yellow and green.
thats probably it, it was in the same loom as the other t-stat housing sensor. any chance you could take a picture of the sensor itself? or know what it's called incase I have to buy one or llok it up in parts exchange?
I can try to get over there today when I get off of work. Its just a single "prong" sensor in the lower housing.
There are 3 sensors on the thermostat housing. Top one with oval plug and small pins is for the ac. The middle sensor with 2 larger pins, positioned in an L fashion is the coolant temp sensor, for the ecu. The 3rd sensor, lowest on the housing is a single wire coolant temp switch. It is used for the dash temp gauge.
