2G Wire behind battery
2GturboTALON
607
6
Nov 26, 2002
St. Peters, Missouri
Ok i was taking my battery out to test it and i notice there is a wire alone behind the battery. It runs from the wires that ground behind the battery. My question is does anyone have anypics of behind there battery so i can fugre out where to connect this wire. There is a bolt to the right of the one that has 4 wires connected to it(grounds), with nothing on it.
I just looked at my car and i saw the 4 wires grounded at one bolt on firewall behind battery but i dont know what mystery wire your talkin about
The only other wire is a real thick wire that grounds to a bolt about 4 inches about the 4 small wires.
that looks like the wire that you ground to change the base timing, but without the plastic connector on the end of it.
