Windshield washer system!!!
baker41o7
Feb 11, 2009
Fort Benning, Georgia
I bought a 98 GSX with no windshied washer system. Due to the fact that the army is ###, not having one will "dead line" your vehicle and they wont let me drive it until its fixed. Ive researched and googled but I have found no forums/pictures of someone replacing the whole system. All I want to do is fix the front if possible. Can anyone help me?
http://www.dsmtuners.com/forums/new...ose-routing-washer-wash-tank-tube-tubing.html
Does that help you? Are you planning on buying all new parts? If so, I could get you part numbers but I'm sure it will be very pricey.
Thanks a ton and I already got them from the dealer. For the complete system front and rear it was like $730.00. Im hoping that I can just get the front resivoir and motor and band aid it till I get back to my home where I have a shop to fix my own stuff.
If you don't want to mess with putting the factory stuff on right now you can rig one fairly cheap from a parts place. They have universal over flow tanks (small square ones) that can be made to work fairly easily. You'll need one of those, a stand alone pump motor (GM ones start out pretty cheap), a couple of feet of washer tubing, a small switch, and some wiring. Simple circuit for the wiring from fuse box to switch to motor + and a ground wire. Wire ties to hold it in place. The only thing you may have to buy would be a nozzle if yours are gone. It will not be pretty but it should satisfy any inspection needs.
