Will this work with my Garret T25?
videogamemaster
129
May 28, 2008
Peyton, Colorado
Umm i would go through one of our vendors for that. I know that t3 takes a certain line, t4 takes a certain one and mitsu the same. I wouldn't test my luck with the ebay one simply because it does not same mitsu applications.
T25. But just to ask, where did you get your T25 from? Because the stock T25 was one the only one to my knowledge with a mitsubishi hotside on it. All the other ones were T3
Ordered it form a member on here... Said it was a Garret T25 and he said everything should bolt up the same as the stock T25
Yeah I have decided to go with Extreme PSI
Garret and mitsu t25 are diffrent. Diffrent flanges adn lines and such.
Garret
Mitsubishi
Pics for comparison. If you need a mitsu t25 pm me.
If you bought it from someone on the boards then it is almost sure to be off of a DSM and therefore right. My oil feed didn't break when I took mine off.
Go with the link from extremePSI or another DSM vendor and choose the t25/t28 option.
Edit: also note that you will not be relocating, your oil feed is already at the filter and the 90 degree fitting that you screw in will look kind of weird because the hole is at an angle.
well all the tutorials i read none of them actually made a good clear description on how to remove the oil feed it just says use a 7/16 wrench to remove and i think i found the place where i am suppose to disconnect it but when i try it just starts to bend the line
Correct me if Im wrog but wern't the stock T25 turbos on 2g's made by garrett. ### Im pritty sure the stock turbo I took off my car years ago said Garrett right on the compressor cover. And those pics above look more like a nissan t28 and an aftermarket t28.
