will this tb work need help fast
white90gsx
674
Dec 21, 2006
Wilburton, Pennsylvania
I need a new tb for my 2g tsi and I found a 1g 4g63 non turbo motor with tb and all the sensors work and will this work on my talon?
Ok I read how to install the 1g tb to a 2g. Now I just want to see if the other tb is screwed up now can I just throw it on hook the tps up on the 1g tb and the iac and should it work...also should I just block off all the lines then if I don't need vac?
The 1G nonturbo throttlebody is 60mm as with the 1g turbo TB. The only difference is that the 1g nonturbo TB has a flange casted into it that you use a hose to slip over it (think intercooler pipes). The 1G turbo TB, as with other TB's, uses a TB elbow. So NO, it does not directly fit onto your stock UICP, but with modification you can. Please research that before you commit to the project.
Yes...well I did try it and i'd rather just wait until I get the 2g tb ill upgrade later
