Will this Fit my 1g N/t 1.8 l
Yea it will fit, but you won't be able to use the filter b/c DSM has the Mass air flow sensor in the air filter. you could use the pipe, thats about it. if you go onto www. cosmoracing.com they have the pipe and the filter that will be compatible with our MAS. Hope that points you in the right direction
yeah you can use it, but you will need a new coupler for the one end so that you can hook your mas up to the pipe and just throw away the filter that comes with the pipe
bartels903 said:
What exactly is a MAS and do I have to have it?
A Mass air flow sensor meters the ammount of air coming into your engine and if you plan on having your engine run, your definately going to need it
no that wont fit, its for the 1st gen.
oh wait my mistake, im stupid for assuming the topic in the 2gnt section would be about the 2gnt... :rolleyes:
please post in the right forum.
^^ what are you talking about, It's in the non-turbo forum, not under the 1g or 2g. And even if it was.... Can you read? but thanks for the other replies guys, i just dont like flamers :thumbdown
We have a specific 1g N/T tech forum where I moved this thread to. He is right that you posted in the wrong forum.
GSGoinFast: you can just report the thread without the smartass post.
yaa i reported it... i was haveing a rough day yesterday, sorry everyone.
Alright I don't really have the 50 bucks to shell out for cosmoracing.com is there any alternatives (sp?), and what are they?
you could keep your stock pipe
or custom make one....
thats about as cheap as your going to find it
That product the first one is on its way, i forgot to tell my dad to not order it for me. and i was wondering how i could make the MAS fit if it doesn't have the adapter? and what i meant by the 50 bucks is that link you gave me to cosmoracing has the filter and adaptor for 50 bucks and i dont have that at the moment. so is there anything i can do? sorry if i confuse you, im kind of confused myself
:cry:
yes you can use that one if you really wanted to although 50 bucks isnt bad . u can use it but you cant use the filter you would have to either buy a filter for the car or jus use the stock one what you do is you jus take the stock shell that the stock filter sit in and cut it off rite after the clips where it clips on and you can put the mas in there and ur filter wont be in that little box then you can jus get a piece of rubber or something and connect the mas housing to the pipe i did that before i had a turbo worked out jus fine
:dsm: brian
