Will this BOV fit my 2G?
chet1185
317
Feb 15, 2014
trevorton, Pennsylvania
Stock 2g, will this work or no?
[ame=http://www.ebay.com/itm/131122037782?redirect=mobile]25mm Adjustable Plumb Back Blow Off Valve Recirculating Bypass Valve BOV | eBay[/ame]
It will work to recirculate but not sure about the flange part. It says its a 25mm inlet so measure the hole where the stock 2g bov is and if its 25mm it should work just fine. But then again its eBay so who knows LOL! Why not do a 1g bov swap?
Just trying to get it up and running for right now. Then i will get the stuff i want.
Cant find a 1g, i guess i cant view and post in classifieds yet
Stock the bov should open at 16.0 in-hg if you do the conversion, or find out what the one you found opens at it should let you know if your going to break something or not. Again check what poster above said to verify it even fits.
