will not idle on start when cold
tsieagletalon
Jun 4, 2005
kennebunk, Maine
car starts and will not stay running unless you give it gas and if you dont then it will die but when its warm it will idle between 1800 but drives down road fine
mine does the same thing but i turned my idle down so it idles at 1000rpms when its warm i think it has something to do with the cold idle but am not sure i would like to know too
Two things that come to my mind: Fast Idle Thermo Valve and the ECT sensor (coolant temp sensor). Search on how to test these to see if either is the problem. The car will not idle when cold if either of these are faulty.
