will hx35 fit good with a stock manifold and a t3 adapter?
redline7
69
Jan 21, 2006
kissimmee, Florida
I am curious to see if and how a hx35 would fit a 1g with a stock manifold and one of these t3 adapters found on ebay. I am guessing it wouldn't clear the water pipe. wanna see if anyone out there has any experience with this
I am very familiar with that thread but it doesn't give me an answer to my question.
No, you aren't.
Your question is answered in the posted thread.
Try reading more than the just the first page. Or, better yet, searching in the posted thread.
You could use a Hahn racing spacer I think its like $80 or whoever makes them cheaper. I used that and there adapter for my hrc s16g. Has worked fine for many years and no leaks for me at 20psi. But I don't know with the holset you might battle leaks if everything isn't perfectly flat. They recommend not using gaskets for some reason. I think I only used one from the mani to spacer and then spacer to turbine housing don't use anything but copper spray. Anyway it could work like Justin said 2" spacer.
http://www.turbosystem.com/hahn/parts/install.htm
As stated before It well not work on a stock manifold. Even if you dent things
