Will GS Radiator fans bolt to a GSX?
Yes it will, but you'll need different hoses. GSX/GST radiator get its water from the middle, while GS/RS are to the passenger side. At least it my case when i tried this.
My question was, will the oem/stock fans from a non-turbo RS/GS 95-99 eclipse bolt up to a OEM/Stock radiator in a turbocharged 4g63 GSX/GST 95-99
Basically I need a radiator fan replacement for my gsx
I am using an aluminum radiator meant for a 2g turbo in my car with my stock fans for a 420a, so yes they will attach to the radiator just fine, not positive about about being the same power plugs though.
Yes, the fans from a NT 2g will work in a 2g Turbo DSM. I am personally running the AC fan from a Spyder GS and it dropped right in with no issues. The fans from a 95-00 Avenger appear to have the same bolt pattern as 2g DSM fans, but have a slightly different part number. So I can't say for certain if it is a perfect match, but I wouldn't pass one up if you can't find any DSM fans.
On a side note, I LOL'ed at all the reading fail in this thread.
