will a 91 talon 4g63 turbo go into a 93 eclipse gs?
DMJ2
Jan 12, 2005
augusta, Georgia
ok im about to buy me a engine out of a 1991 awd eagle talon tsi(4g63 turbo) i have a 1993 mitsubishi eclipse gs (4g63 non turbo) will this engine bolt directly into my chassis,what all do i need and what all do i have to use off my old motor? do i need any different wiring harnesses.do i use my 5speed tranny since mine is only fwd? please help me before i make a mistake of putting this into a car thats not compatible. thanks alot :dsm:
This isn't extreme. It will be moved. Check the 1G turbo threads. Tons of info on what you need. The swap is pretty much straight forward.
It's called a "Shift" key. It allows you to write capital letters, such as "I". You should look into using it.
Thread moved to Newbie forum.
Yes you can do the swap but there are some things you need to do. Look in the NT forum or in the tech articles there should be some help in there.
Looks like I'd better clear some space in my pm inbox.
"OMG hwo to trubo my 1g gs nt 2.0 dohc motor, some1 said u no" :rolleyes: :| :cry:
"yo guy. do u no how to turbo mi car. gimme a list and rite a step bi step insturktion. k, peace yo."
"Ok. Take some marbles and put them in the hole with the cap labeled 'OIL'."
I prefer bb's for their ineteresting sound when smashed into valves and pistons
hey guys he just asked a ? he didnt ask to get bashed on some ppl on this board are dicks!!!!!! anyways yeah the motor will just drop in and yes u can use your trani. You should think about gettin a nice clutch and flywheel thow!! sorry i couldnt help u anymore
Well, this question has been asked a lot of times. A LOT of times. He could've checked the VFAQ and found this
If he searched '1g engine in 2g' he would've found this and this,
If he searched, '6-bolt swap' he would've found this, this, this, and assloads of other posts about a swap that's as popular as the SR20, B- and K-series swaps, and 3-rotor swaps.
All that and then some with just a few keywords and a bit of digging. And that's just from this message board. Imagine what I would find if I used Google.
