Will a 14b Wastegate acuator work on a Mutt level 4 ?
HondaStalker
64
Jun 20, 2003
Will it some what work ?, I have the wastegate mounted on there and its not really bent at all, the flapper is open just a VERY VERY little bit.
the specs on the turbo are.
Garett ta compressor housing, h3 wheel,mitsu. center section,upgraded thrust bearing, .60 a/r, 60-1 compressor side.
No that wastegate actuator will not work. You will need a heavy duty garrett one.
