wideband & injector problem help!!!!
awd2gsx82
61
Jan 9, 2008
morrison, Illinois
ok its like this i got a aem wideband kit and 650cc injectors from a kid off of another forum.
well i installed the wideband and all that came up on the display were lines.
what could be wrong?
next the injectors, i installed these and one of them is stuck wide open?
what could cause his?
can i fix either of these problems? please let me know. any help would be great.
thanks
Are you saying that when the car is running, the WB reads --- ? You do have the sensor attached, right? Where did you tap for power?
How do you know the injector is stuck open? If so, your car should be running like crap and fouling plugs like crazy.
yes it reads ----. its tapped to the cig lighter for power.
as for the injector it is fouling the plugs and we switched locations to make sure and it fouled that plug also.
