White smoke always
psycho98gst
Feb 12, 2004
Clifton, Colorado
I have white smoke all the time, no loss of power until I fowled the plugs due to driving it after the smoke started. Smells like burnt oil, very thick white blue smoke. no loss of coolant, but large loss of oil. took all plugs out covered in black. also disconected intercooler from intake and intake from turbo no smoke between turbo and intake. could turbo seals cause this heavy white smoke. also took out all spark plugs after running and 2 cylinders had smoke coming out of them, I assume the exhaust valves were open in these cylinders and smoke coming from exhaust. Need help!!!!!!!!!!!!!
check the compression from the pistons, its low the piston rings are bad, if not could be the valve seals. Check the turbo for shaftplay too could be a bad seal leaking. good luck.
  • Wanted 6 bolt NT water pipe
    • chrisman287
