White or grey smoke on WOT.
jshuman
254
20
Oct 8, 2006
Vienna, West Virginia
I have a 95 talon with a 6 bolt. I just bought it with all the mods already done. It was dyno tuned by extreme motorsports and put down 395. At WOT, white smoke comes out of the exhaust. I am running a dbb 50 trim, 650's and alcohol injection. I did not know if the alcohol could be the cause of the smoke. The car alos has no cat. Here is the full mod list.
6 Bolt w/wiseco .020 pistons 1G Rods
TRE Stage II Peformance Transmission Rebuild
w/electropolishing option
New Clutch Fork
SS Clutch line
SBR 3500 Clutch
Fidanza Flywheel
External Oil Cooler
3g lifters
HKS 272/272 Cams
Cometic Headgasket
Fal Dual slimline fan
GM Maf
MafT
Tial BOV
Autometer EGT, Boost, and Oil Pressure Guages
AEM UEGO wideband
Turbo Timer
Projector Halo Headlights
New 97-99 Front Bumper
Used 97-99 Rear Bumper
Brand New 97-99 Side Skirts from Mitsu
Brand New GSX style wheels
Symborski shifter kit
Shifter bushing kit
B&M Shifter
RRE Catch Can
SBR 2g FMIC
PTE Dual Ball Bearing 50 trim - 5032
w/ported inlet and outlet port
650cc injectors
Walbro 255hp pump
Aeromotive FPR
FPR Guage
SBR FPR Kit
3in Dejoon tool intake pipe w/ K&N filter
DSM Link
NGK Plugs
Magnecore Wires
SBR Spark Plug Cover
Front Drilled/Slotted rotors w/Hawk Pads
New Rear rotors and pads
SS BrakeLines
3in Downpipe, no cat, 3in muffler
Vis CF hood w/sparco hood pins
Hyperdrive Alcohol Injection kit
AEM Map sensor
Extremes 02 Eliminator kit w/Tial 41mm wastegate
Hyperdrive MBC
Tien Basic Coilover kit
New leather shift boot and e-brake boot
Evo8 Shift knob
Panasonic color cd player
4 Pioneer Door speakers 6 1/2 and 6x9s
2 Kicker subs in a custom sub box fit into the spare
tire well
2 Kicker amps pro. installed
Battery relocated to trunk
Viper Alarm
Sparco Seats
Front Rear strut bars
Brand new floor mats and floor carpet
New sunroof weatherstrip
New Hatch weatherstrip
New Drivers side door weatherstrip
Brand new paint! The car looks awesome with
this paint. The car was originally black but now
was painted white. They did an awesome job as
you can see by the pics. And you can also see
that the door jamps are still black but as you can
tell from the pics, it isnt noticeable or anything.
I think thats basically it...i'm prob forgetting something here and there. But that's the main bulk of it! As you can see, no corners were cut and basically everything in the car is brand new!
Everything was also professionally installed!
And everything listed above...right now has less than 1,100 miles on it! The chasis has 154,xxx miles.
This car has always been taken care of from when my friend owned and while i've owned it...now its time to let someone else have fun with it.
The car was dyno tuned by extreme motorsports. They also installed the hyperdrive alcohol injection 02 elim w/tial wastegate. The hyperdrive alky system is something extreme only reccomends and sales for alky injection. It is the only one they will sell and its the one they use and love! It costs $700 itself uninstalled.
If someone could help me out I would really appreciate it.
Thanks!
assuming you aren't having to refill your antifreeze once a week this is fairly normal...with the mods you ahve listed and no cat you are bound to make a little smoke now and then...this is assuming it isnt a thick constant stream at wot.
Smoke colors:
Black - rich conditions too much fuel
Blue - oil leak
White - antifreeze leak(or combustion additives such as alky)...
All catless cars will make the occassional smoke puff now and then, just make sure its not a constant thing...
Thanks for the help guys. To answer your questions, no the smoke is not continuous. Actually I have only seen the smoke in 2nd gear, but no other time. Also, a compression test was done and the numbers were well within tolarance. As for shaft play, would that be a problem on a turbo with less than 5,000 miles on it?
