Which wire to connect MAF-T on 1990 CAS?
tsi1991awd
1,366
6
Sep 28, 2008
Puyallup, Washington
In the process of installing my GM MAF and MAF-T...question is, there is one white wire that needs to be connected to a wire on the CAS. The directions for the MAF-T tell which wire it is on the 91+ CAS but not for the 90. And everyone knows the 90 is different. So I ask....which wire on the CAS do I connect the white wire from the MAF-T to??
Thanks....so I don't need to hook it to the noise filter or anything like that? Since this sends signal for the RPM....well it sends signal to the tach anyways.
when i hooked mine up the instructions i used said this Use the supplied TAP and SPADE connectors to connect the white Translator wire to an RPM signal. The CAS (Crank/cam Angle Sensor), pin 2 (black wire), is a good place. and it works great.
Yea, that's for a 91+....the 90 is different, which is why I was asking about it.
