1G Which tranny cables and bracket to use?
you will want to use the ones from the 92 if you have them otherwise any from 91-94 will work.
You also need the shifter base to be the correct year. The base, cables, cable bracket and selectors on the transmission need to be of either all 90 models or 91-94 models.
