Which LSD for FWD???
4g63telantra
454
Dec 10, 2004
Toronto,
K I got a deal on a LSD insert here in Canada.
Just not sure which one I should go with, he sells mild steel or spend a little more and I can go with a tool steel insert.
What do most peple use on a FWD tranny?
Does it really make a diff on what one I should get?
Tranny inserts not really the best way to go. IMO and most everyone else's if its a DD car then go with Quaife, if 90%+ at drag stripe then KAAZ.
Some break, and some don't. I would have better piece of mind that KAAZ and Quaife aren't as prone to break, and yes under high HP levels they do break, but they both have life time warrenties.
I can attest also and it's not just because we build them. They have both been wooped on pretty hard in two front wheel drives both making 450 - 550 horsepower depending on what fuel we could get :) Both of those cars had slicks.
The only problem we have with them to date is installation error. MAKE SURE YOU PULL THE RETAINING CLIPS OFF :)
If you want to see our installation instructions i keep a semi hidden link on our website here
http://www.slowboyracing.com/sbrfaq.htm
Just click on drivetrain and download the PDF. Sorry the page isn't finished just yet.
