which fuel pump and injectors???
Onnipotente
105
Oct 16, 2003
I need a new turbo so i plan to get the evo III 16g turbo...
right now i have a k&n filter, greddy bov, boost guage, air/fuel gauge...
what i plan on getting is:
16g install kit
greddy intercooler piping
boost controller
fuel pump
fuel injectors
s-afc
i am planning to do this on my stock exhaust and intercooler
question is: which fuel pump and injectors do i get???
also are there any other supporting mods i should do?
You should get 510 cc injectors, because with the power you make with the stock exhaust you won't be able to make use of injectors any bigger than that.
A Walbro 190lph and 550s would work well also, then when you get the exhaust you can turn it up a bit more. The 550s should be able to be tuned with the SAFC you said you were going to get. :thumb:
please just search... there is someone everyday asking the same question you are and I know i'm not the only one getting sick of it. There are also tons of people on the site that are running the EvoIII16g why not look what they are using.
running a new turbo on your stock exhaust is also not the smartest thing either. if you want to know why insted of starting a forum and asking try searching for the answer because it is out there, i've seen it
