Where To Tap Oil Feed?
Riceboy
55
Jan 25, 2004
LaPorte, Indiana
O.K. i hav no idea where to tap the holes if i have to? but where do i run the oil feed and dump at on the block is there a special place for the dump that i can run it to with out drilling a hole or nething? and where does the feed go in an oil stream on the side of the block or does it go by the oil pan?
Thnx 4 any help :dsm:
selmerguy said:
look at my gallery and you will see i used an adapter from summit for the oil feed and you need to tap the oil pan for the dump tube.
Is it the sandwich adapter?
and where can i get it summit u said? and what was the price and name of it?
Thnx
Terry
Also will it be o.k. if i dont run an oil cooler right and can i just run the feed from that and run the dump back to it on the other side?if not where do i run the other outlet to? just to the feed and do i have to make a hole for the dump 4 sure?
thnx
thnx
i have no idea what your talking about here. are you saying get the feed from an oil cooler and dump it back to the other side of the oil cooler? here, what kind of turbo do you have? i have a T3 and i ordered a oil line kit off ebay for $70 and it has everything i need with good quality and it fit good too. i got it just to save the headaches of finding the right fittings and what not. and yes, you have to drill the oil pan.
What is the link for the oil line kit you ordered off ebay
Hey, I really need that part number for the sandwich adaptor. Theres one on there that says its universal.. but i dont wanna guess and find out its the wrong one.. thanks for the help!
White97eclipse said:
Hey rustie, are you going turbo???
Heck yes!!... haha, yea ive got half the stuff i need. All brand new parts. Heres what i have:
T3 turbo (.48 a/r compressor, .50 a/r turbine)
Large FMIC and couplers/clams (Intercooler core 21x9x3)
38mm External Wastegate
Charge Pipes (2.5", my friend is gonna help me weld and fabricate)
Log style turbo manifold
Gauges (boost, a:f, oil pressure)
So all i need is:
Oil lines
Greddy type RS bov/ flange
FMU 12:1
Missing Link
190lph fuel pump
All parts total at 1600, everything new.. including shipping!
so yea, half way there. I was really hoping to see you at the meet on the 12th last month. Im gonna need some tech help. The forums help a little, but i wish i could have someone actually help me out with it in person. I have a couple friends that have turboed their non turbo car, but not all of it is exactly the same. If you could help me out since your not too far away, thad be great.
But yeah, i kno that you can route it somewhere else w/o having to buy the sandwich adaptor, but where is the safest place? Ne help would be nice. Trying to save a little more on money! :thumb:
Hey is it smart 2 get the missing link when putting the turbo in a idont have a maf sensor so i should b fine right?
Thnx
Terry
ok i was wrong about the t3 oil line kit i ordered. it didnt come with everything i need. it came with a 1/8 tee. well the stock oil pressure sending unit is 3/8. so you have to go to home depot and buy a 3/8 female tee, 3/8 hex nipple, and a 3/8 to 1/8 reducer. cost $6
  • Wanted 2g 2g Hood latch support
    On the hunt for the support that holds the hood latch assembly.
    • jesse12345
  • For sale 4G63 Hallman ES Boost Controller
    Boost controller
    • jpturbotalon
  • For sale 4G63 6 Bolt Kiggly Modded Oil Pump Pickup
    6 Bolt Kiggly Modded Oil Pump Pickup $95 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
  • For sale 2g NEW 2G OEM Timing Belt Tensioner Arm
    NEW 2G NEW 2G OEM Timing Belt Tensioner Arm $45 + shipping & paypal fees* these are $70 online...
