Where to set the mbc
Given your mods I wouldn't boost much more than 14 psi. You need to make sure that you are supplying enough fuel to the engine so run the highest octane you can. Also you may want to look into a fuel pump rewire kit. This will allow your stock fuel pump to flow it's maximum capacity by supplying it with a higher voltage. Good luck -Jon
