where to hook up for a vacuum leak test?
slider85
469
May 21, 2004
Langley,
i did a search but could not find any diagrams or answers. Where should I hook up the vacuum gauge on the 2.0L NT to check for vacuum leaks? Should I "T" into the one off the fuel pressure regulator or what? That seems to be the only point unless I use the brake booster one but I don't think that would work. Need help quick because I want to do this today.
I went ahead and used the FPR hose for the test. The car idled between 1000-1100 RPM and the vacuum read between 19-20. I believe that is good. I know my idle is high because I hated the amount of vibration the engine had when it was lower so I raised it. Any comments I'm happy to hear em.
i just moved the BISS screw. I think next time I take it in to a shop I am going to get them to check the timing and reset the idle down.
