where to get synchros
ok everything i see says synchros help when shifting in high rpms, mine is grinding when i engage the clutch in 1st gear, and only first gear, like it wont go into gear is that synchros because i was told it was, thanks for the site btw
Make sure your clutch is adjusted properly, as an out of adjustment clutch is the biggest issue with the trans not engaging gears properly, and this can also lead to the premature wear of synchro rings. There's a video in the link explaining how to adjust it properly, scroll down a little and it's the first vid:
Jacks Transmissions LLC — Tech Articles
Jack also sells synchros, gears, complete clusters, or full rebuilds.
Jacks Transmissions LLC — Mits Parts
