Where is the VSS on a 4g63?
SPD CAT
30
Dec 18, 2005
macedonia, Ohio
my speedo is out for good, my Haynes Manual just shows the VSS for a non turbo, it says that there is a bolt that holds it in place, the only thing i've seen was a harness going to the tranny almost under the upper intake tube, but no bolt holding it in place. from what i understand there is two, and i want to replace both, any info greatly appreciated!
thanks so much for the reply, im gonna check that out on my car in a few minutes, so i read the rest of the posts there, does mitsu not offer that anymore, is it the same for a 1G? cause i have a first gen FWD 5spd that i used as a donor for a 6bolt.
thanks again for the help on the vss!!!
