Where is my Fuel
DearDoger
123
Jan 26, 2008
Battle Ground, Washington
HELP A NEWBIE this is probably something simple So i did my clutch and now the car isnt getting fuel when i try to start it its just turning over and over with no fire or compression. it has spark so what could have messed with the fuel supply when i did my clutch.
Make sure you didn't remove the 20 or 30A fuse that sends power to the injectors. I believe its named as motor. Can you hear your fuel pump turn on when you crank the motor?
