where can i get oem style replacement floor mats?
I'm bringing this back because I finally got the Spyder out of storage over the weekend. When I went to install the mats, following the included instructions of course :), I found out there is a difference between the Spyder mats and the hard top mats. I was right, my old mats said Spyder and these say Eclipse, which isn't a big deal. But problem is there isn't a cut-out on the driver's side mat for the hatch locking mechanicism on the floor.
Does anyone have the part number for the Spyder mats? I can't find it anywhere and the dealer I purchased the mats from said everything is lumped under Eclipse. I guess they can't find the part number either.
MR356644
52-310 (Interior > Floor Mat)
Yup, I used a vin number from a 97 Spyder with tan interior. I didn't compare the part number to a non-Spyder but I can do that just to verify when I get home today.
Or, more likely, Brian will beat me to it ;)
It is the correct number. I cross-checked it with a '98 GST and a '99 RS and both of their floor mat part numbers are the same - yet different from the one Eric posted for the Spyder.
And I called JNZ Tuning and they guy I talked to verified it was the part number for Spyder floor mats (which are different from coupe floor mats). :thumb:
I would double check though that you get both driver and passenger floor mats when you order as it doesn't say anything about that or show anything in the pictures. For the price, I would hope you'd get both, but you can never be sure.
The ebay thing says non slip rubber back side thing. All I know is my stock mats are ripping on the backside and leaving pieces of mat in the car.
Ebay will also tell you that you will gain 25-30hp by purchasing an intake, so you cant really rely on what they tell you. But if you need new floor mats and want to give it a try, by all means give it a shot and hopefully you will be satisfied.
"Same as Picture Shown
Rilliart Logo
4 pieces per set
Non-slip rubber backing design
Black Color
Preimium Grade Quality"
God, how could you miss?
I don't see a grommet for the retention hook, and just going by what most cheap aftermarket mats are like, they'll be shot by spring.
