where can i buy transfer case bearings at
I vote Tim at TMZ. You can also get them from the dealer, but Tim will probably be cheaper. I have tried to get them from a bearing house, but usually they either can't get them, or they are really expensive compared to a dealer.
i could not find transfer case bearing on those sites i only need one bearing can i buy them one buy one at a dealer or do i have to buy a kit
I would just buy a good used transfer case, it will be cheaper and easier in the long run. You will probably spend 100-200 dollars just getting the bearings, than hopefully the gears are still good. If not there's another couple of hundred dollars.
I just got the number off the old bearing and went to napa and they had it in stock.
Yeah, because a used transfer cases with 100K+ on it, and 50k of that without oil, are in great shape.
At some point dsmer's are gonna have to quit with this "junk everything becuase theres a million good used ones out there"attitude. At some point mitsu is going to run out of new ones, and the drag racers are gonna break all the "good used ones". When a rebuildable core costs you $500, you're gonna wish you kept that one that only had a bad bearing.
