When will I over run my 255
Hiitman
482
4
May 12, 2004
Colorado Spring, Colorado
I don't want to switch to a dual in tank setup if I don't have to. Here's the parts of my setup that I think will determine this
PTE 4431 25-28psi
255lph
Aeromotive fpr ~38psi
1600s
-6an feed/return to tank
E85
Dsmlink
Flowing about 49 lbs/min at 6000ft. Also, will the car run uncontrollably lean if I do start to run out of pump?
49lb/min at 6000ft is the same as 49lb/min at -500ft
Good call.
I guess I'm just curious as to what airflow range should I start to expect to over run that pump.
A walbro 255 hp fuel pump will flow enough to supply 850cc injectors at 100% IDC at 35psi. You can look in various places on the web to find out how much 4 850cc injectors support :) .
E-85 uses 30% more fuel, a rewired 255 starts to run out around 450-500whp mark on gasoline, subtract 30% for E-85 and it gets iffy....
See here: E85 Fuel Pump Calculations
Theoretically, you can flow about 52 lb/min at your highest boost level and still be ok...but thats dangerously close to 49 lb/min. IMO, I'd go for dual pumps just to be safe. I'd rather have more than enough fuel rather than too little.
    • 4g63tv
    • 4g63tv
  • For sale 2g 99 2G parts
