Wheels Opinion/Suggestions
MN_Eclipze
84
Mar 16, 2009
Minneapolis, Minnesota
I currently have a set of 18*9 with a 38 offset on my car; lowered 1.25. No fender rolling. Tire on it is 225/45; 235 will rub.
Im looking at the ROTA SVN and was wondering how this would fit onto my 97 spyder. Wheel spec is 18*9 with a -30 offset. Any pic of this wheel spec on your car would be great. Thanks.
18x9.5 +22 with 245/35zr18 Federal 959 RS-R
I'm not sure how close he is or what camber he is using, but if i find out ill let you know.
The Federal 959 RS-R 245/35zr18 are 9.8 inches wide around 248mm, you would need to roll your rear fenders for sure, im using nitto NTO5 255 which are 10.12 so is around 257mm so his wheels are 5mm less closer than mine to the arm, but sticking out more.
This is all i can help you bro...
kidtsi -- Thanks.
I am not a pro when it comes to wheels spec. I might probably stick with the spec that I see on the wheel that they have available which is 18*8 +38 -- 225/45/18. How does this setup look or sound like? I am totally a NOOB on this.
I'm on 18x8 +40 with 235/40 tires. They are flush with the body so they look great, but with a 1.75 drop, rolling the rear fenders is a must for me.
kidtsi -- Thanks.
you have 18x8 or 18x9 +38? if they are x9 ill will probably try to put a 235/40 at least, i don't like stretched look at all. if they rub to the arm trow some 3mm spacers and done.
