Wheels, fitment??
c_riggan
61
Jul 24, 2008
Surprise, Arizona
I have a 96 GST which is totaly stock. I also have a 93 Skyline R33, which has had an accident (right after I ordered new rims for it). The wheels are 5x114.3 pattern and in the sizes: 18x9 ET 30 (Front) and 18x10 ET 20 (Rear).
Will these fit the 2g DSM? More worried about the fronts fitting. Not so much the rears, as I can make fenders wider in the rear a little. Thanks for any input, sorry about the section in which this is posted, but I have not much access.... ???
Chris
Thank you kindly.
Hope they will fit. The R33 doesn't need them anymore (never even got to put them on.... Rear quarter panel is smashed in and have to order a new one, drill out welds, and remove, then put in new one, weld back up, straighten little bit of chassis in the rear, and paint. Too much to do now, and wont see it until next year when I go back to Germany for a little while.
I run 18x9 +30 stock spec. alignment and stock height as of now with fenders rolled. As far as the 18x10 I'm pretty confident they would fit as well the deal breaker would be the tires you go with. Don't mind the condition of the car. Don't have any better shots but you can see how far it sticks out.
