2G Wheel bearings
I went through the same thing, ended up buying a whole new (used from dsmtrader.com) wheel hub assembly (front), as they are pressed on in front. I could not find a shop with a powerful enough press to get the old one out of the assembly. I also have replaced the rear ones, they run ~$40 and with right tools take less than an hour to replace. Hope that helps :thumb:
Yea the rear are the ones that need to be replaced. On a 95 gsx tat im looking at. I wasnt sure how hard itd be
