wheel bearings or hubs
I know some cars have just a wheel bearing and some cars have that hub. Which is a big part and the wheel bearing is a smaller part
I think what the OP is asking is. If you want to replace the bearing, do you have to buy a whole hub with the bearing inside, or can you get the bearing separate. Well Yes you can buy the bearing separate, but I wound urge you to buy the whole hub and bearing together as its a real pain the other way.
well if its a 1g then he has to get the bearing pressed out. 2g you can just buy the hub which has the wheel bearing in it.
