What's wrong
Jetblack
149
Apr 5, 2003
Baton Rouge, Louisiana
I can't get into gear unless I rev into the higher rpm's then it'll fall into gear. How should I go about diagnosing this? There is fluid in MBCylinder.
check the clutch master cylinder, then check the slave cylinder to see if its leaking. this actually sounds like a synchronyzer priblem to me. try getting some be synchro shift and see if it helps.
what is be synchro shift
i think he was trying to say get some trans fluid made for a synchromesh gear box, like redline mt-90 or bg synchroshift or bg synchroshift II my recommendation, very pricey worth a shot,(not as pricey as replacing the synchros) before ruling its the synchros because then it would be time to cry about how much that will cost you
you will only need to buy 3 quarts but you will use something like 2.3 or 2.5 i don't remember i am sure some one around here knows exactly how much, doesn't really matter its almost impossible to over fill it a lot.
