What's the difference between these two Cardone computers?
No your car doesn't have the California EGR so you don't want the California ECU.
like getting a new one.
I think I have some pictures from a few Cardone rebuilds, not what I would call like getting a new one. If I say so myself they looked much better when they left here. :)
get the California one pop the cover and remove two resistors I believe it is. Itll put it into AWD Federal Emmisions.
so when you swap one of these out for another is it just a matter of plugging in the harnesses then turn the ignition or is there some prep?
Just to reduce any chances unbolt ## negative terminal wait a min or two then swap the ecu's out. Then reconnect and fire it up
